Old 07-25-2012, 09:22 PM   #13
BYprodriver
BYprodriver's Avatar
Originally Posted by ekam View Post
Exactly. The cost to rotate the tires at the tire manufacturer's specified interval will end up be the same cost as buying new tires. Not to mention they require 4-wheel rotation which will make warranty invalid for our cars unless you're running same tire size all around.
People should read the fine lines more often.
If you did read the fine lines you would see that the mileage warranty is halved for cars with different sizes front & rear.
