Old 06-30-2012, 06:47 AM   #1
ppbon
ppbon's Avatar
If you are replacing the tranny mounts ....
Originally Posted by Reggie&Sue View Post
I just replaced my transmission mounts on my 2000 986 S. The symptom was drops of dark, viscous oil leaking from about 1 foot inside the rear wheel, which eventually grew worse. (This oil is the damping fluid inside the mounts). The leak was on the passenger side only, but the mechanic told me that the other mount was close to failure also.
OEM Porsche mounts were $324 each, and 4 hours labor charge.
... Don't buy the Boxster mounts.
If you purchase the Boxster mount it comes with the bracket as well with doesn't deteriorate at all.
The trick is o buy the motor mount for the 993. It is the same damper that the Boxster uses, but by itself it costs half as much.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
