Originally Posted by kingsilver
Thank you for the info, the rims are in transit, So I do not have them yet. One f you says "you will need a spacer", one says you will not. How do I know if I need them or not, and if so where do I get them, also can I have the part # for the clips please.
JK
The part number for the clips is 999.651.230.02. Your can pick them up from your local dealer. I don’t remember however if they have them in stock or if they are special orders. They are $.79 or so depending on the dealer.
In regards to the spacers being needed, it really depends on the wheel offsets. In most cases they are not needed and the wheels can just be bolted on. In other cases a slight adjustment to the camber of the rear wheels can achieve the needed clearance. EVERYTHING depends on the offset of the wheels. Push come to shove you can always use spacers
What kind of wheels are they? Also what wheels did u have on before? Stock 17s?
~James~
