Old 05-01-2012, 03:05 PM   #1
OldMacTech
Little vague I guess. I meant the whole assembly that raises up then lowers to cover the top when its retracted. Boot or boot cover maybe it's called?
When mine has the left side pushrods a the rest of the mechanism connected it raises and lowers easily by hand with very little resistance. When I connect both sides, the right will not go down at all even with light pressure applied by hand. Just curious if this tells why the right plastic ball joint broke. Or.....is is supposed to resist and only move by motor?
Sorry if this is 1st grade material... New to the breed.
Thnx
OldMacTech is offline   Reply With Quote
