Old 04-12-2012, 08:18 AM   #6
goldenhse
Was preparing to use the SIR for insertion of the hub. Was just lineing the hub up by hand when the race stuck to the hub shaft while re positioning, pulling the split race out. I feel it came apart way to easily? Thought maybe bearing pressed in backwards but no indication of front or rear of bearing. Markings the same both sides and measurements all the same with caliper. Both sides appeared identical.
goldenhse is offline   Reply With Quote
