Old 10-17-2005, 06:16 PM   #4
deliriousga
deliriousga's Avatar
Originally Posted by whttkrasst
As for using oil, the electronic dipstick is down to the first mark just below full and I have 600 miles on the car. That also seems reasonable for a new engine. The dealer said it'll go through some oil and need to be topped off now and again.
Make sure you check it after the car has sat for at least an hour. Checking at a fill up will give you a false reading that's lower than it really is.
We have gotten into the habit of turning the key to "on" every morning before starting the Boxster to check and it has never been low. A check at the pump and adding may cause an over-full situation.
1966 Wife White/Brown Top
