Old 09-27-2005, 02:40 PM   #1
deliriousga
deliriousga's Avatar
Cheap source for OEM filters www.pap-parts.com
If the PO did use regular motor oil, I would change it to Mobil1 and then change it again in about 5K miles. There are blends, but they last about half as long as full synthetics so when you "create the blend" you should change it early and your next fill will be more pure.
1966 Wife White/Brown Top
