Old 11-21-2011, 05:50 PM   #2
tonycarreon
tonycarreon's Avatar
... I add 8quarts & check the level with dipstick, if no oil on dipstick I add 1/2 quart. there is no need to try & have the oil perfectly full since overfilling is bad. I try to set the level 1/2 quart low. I believe this helps the AOS last longer too.
don't know about the AOS longevity / underfilling, but...
every other change i purchase 10 qts. when i change the oil i put in 9 qts, then check the level. inevitably i have to add "a little more." maybe 1/4 to nearly 1/2 qt.
that got me thinking, i believe the actual capacity is a little over 9 qts. checked the manual - 9.3 qts, with filter & housing.
