Normally, it takes these cars a couple of weeks to drain a good battery if the car is not used, so I would bet that your battery is weak. Suggest having the battery load tested to see if is even viable................
If the battery checks out OK, I’d get a multi meter and start looking at how much current draw there is at the battery with the engine off. Should be 40-60 mAh, if it is higher, you have a parasitic drain that needs to be located.
