Old 08-26-2005, 12:07 PM   #1
tony2fingers
FYI i just put a kicker solobaric 10" 10l7 in the footwell with the kicker being able to handle around somewhere between 400-800 watts. Seriously sounds like i have two 12 in there. had a custom fiberglass enclosure built (less than 1 sq ft.) and squeazed the biggest baddest subwoffer i could fit in there. Yes i did loose some foot space for the passenger, but the bass is incredible, i only have a 360 watt amp right now, i could probably push a bit over 800, but that would be another project. if you dont want to loose that much footwell space, you could always go with the 8 ", but its not nearly as loud or the bass doesn not go as deep. i could post some pix if you like. Cost on the box and speaker was around $500.
tony2fingers is offline   Reply With Quote
