Old 04-17-2011, 02:33 AM   #1
cavmar
Originally Posted by Steve Tinker
cavmar - if you are handy with a 10mm and a 24mm spanner, remove the poly-rib belt that drives the alternator, power steering, water pump and A/C and run the engine for no more than a minute or so (no coolant flow).
If the whine stops, then you know its any one of the above accessory's or the belt pulley's / tensioner that's causing the noise.
Cheers Steve, defiantly worth a try, I sincerely hope the noise does stop at that point!
cavmar is offline   Reply With Quote
