Old 09-21-2010, 04:00 AM   #2
eightsandaces
Originally Posted by willd
To answer a few Q's first;
- Noise doesn't happen when it's on a jack.
- I did check the rotor guards, couldn't see it touching anywhere.
- No wear anywhere from the tyre.
A friend of mine has asked me if I had the "anti-vibration shims" on my pads.
Well, when I changed the rotors/discs, of course i took the pads out, and put them back in again when putting back together, but I never noticed any shims.
He thinks that is what the issue might be, and that I might be able to fix it with some of these; http://cgi.ebay.co.uk/Universal-Self-Adhesive-Anti-squeal-Brake-Shims-/250695039221?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5e96b8f5
So I might give that a go. If that doesn't work, then I guess I need to look at the bearings...
Thanks for the replies!
Did you manually spin and inspect every wheel? I'm not thinking it's the pads, I'm jumping on the bearing bandwagon, it might be silent in the air because there is no load on the bearings.
eightsandaces is offline   Reply With Quote
