Old 07-11-2005, 11:55 AM   #2
PDXBoxster
something stuck
WoBoxster,
I have a squeal on the left front wheel and it just started happening to day as a drove the first mile or so. I put it back in the garage immediately. I just talked with Jeff Gamroth at Rothsport and he suggested the same thing you were waying, "something, probably a rock or pebble has wedged itself somewhere". He said it can happend from time to time and I live on a short gravel road so it may be the problem. Tonight I will take of the the squealing front wheel and have a look. Jeff said it was important to not turn the disk when the wheel is off before taking a flashlight and checking out the calipers and pads. He felt that if you turned it, whatever is in there could drop out and you wouldn't notice it and then you would be scratching your head trying to find the "problem". I may have to take out a pad or two to get to the problem.
I will let you know what I find out.
"eschew obfuscation"
2001 Seal Grey Boxster
De-Snorked
De-Ambered
...and lots more.
PDXBoxster is offline   Reply With Quote
