Old 08-03-2010, 02:13 PM   #5
JFP in PA
Originally Posted by JoeFromPA
JFP - Can you elaborate or provide a link? I did about 10 minutes of searching and found nothing (except issues on chatter, which is normal with LW flywheels).
Also, since oneof the boxster's issues is supposedly due to a heavy-ass flywheel hung off one side and not enough support on the other, I'd think that a bit less mass would be preferable....
In general, reducing the flywheel mass would offer some benefits (e.g.: quicker revving). Problem is that the dual mass unit acts as a harmonics dampener, absorbing some of the torsional forces on the crankshaft, reducing cracking tendencies. We have encountered problems on M96’s running single mass wheels with out any additional dampening (adding the GT3 dampened front pulley, complete harmonic re-balance of the engine, etc.) The magazine “European Car” did an article about DMF setups about 3 years back, but (if memory serves) the individual with the most data on the subject is Jake Raby (Flat Six Innovations), who probably knows more about the M96 than anyone out there. From one of his postings (concerning using a light weight single mass flywheel on the M96):
Installing this flywheel removes ALL harmonic dampening of your engine and transaxle..
One person has recently broken a crank... He didn't listen to me when I told him what caused his issue more than likely, so he reinstalled the same flywheel on his new crate engine. Two events later I got another phone call from him stating that he had broken another crankshaft and he should have listened to me. He is now on engine #3 and is broke, so broke that he is having to make one engine from 3 broken cores..
Another engine (2.7 DE car) had a knock, it was pulled apart and had a cracked and breaking crank.. When I threw the assembly for this engine onto the balancer it was immediately 10 grams out of balance, when the pressure plate was added that went to 19 grams and the flywheel was nearly new and had never been touched..
Both of these are in addition to the X51 engine that snapped a crank in half last year, also using a LWFW... There have been two other instances of similar consequence that people have contacted me about since the new year, but I did not see their parts first hand.
Harmonics have to go somewhere... The dual mass was utilized for a reason-Components that are forced to absorb them won't like it.. And it appears that these harmonics also end up being sensed by the knock sensors as possible detonation, so then the ECU retards timing and that reduces HP. I have gathered data that proves that these harmonics that can't be absorbed are directly related to reductions in net power, as much as 5HP in one instance from my test car.
Balance and harmonics are two different things... Sure an engine thats out of balance will have more harmonics, but even an engine thats perfectly balanced will still have harmonics that need to be absorbed..
The dual mass flywheel and it's dampening characteristics help to absorb these harmonics, the LWFW does not have any dampening capability because it has no second mass separated from the primary mass by absorption material.
Consider the fact that the dual mass flywheels that do fail may be failing because they are actually doing their job!! A flywheel is a wear item, it is a component that is designed to be disposed of after it's job is complete... A crankshaft is not a disposable item and if not absorbed somehow, somewhere these harmonics will find the weakest link and thats when things break.
With the M96 everything is rigid once the dual mass is removed, that means the harmonics from the engine, transaxle, CV joints and even the axle bearings are all going upstream directly to the crankshaft.
When the mass of a dynamic assembly changes as radically as it does when a LWFW replaces a DMFW the plane of balance must be compensated for, that means even if the flywheel that is placed onto the engine is perfectly balanced, when coupled to the rest of the dynamic assembly it will be imbalanced if the plane is not corrected.
The only way to do this is with the engine disassembled in a balance machine like mine. Thats why I refuse to install a LWFW onto any engine unless I am creating it's engine from scratch and can ensure the unit is balanced as a complete dynamic assembly then indexed for reassembly.
FWIW I have yet to see a single LWFW that has ANY balance marks on it brand new out of the box. Every unit I have spun up has had imbalance that exceeds my tolerance threshold...
When the second mass is removed where do those harmonics go?????
Raby comment
