Old 07-25-2010, 07:07 PM   #10
husker boxster
husker boxster's Avatar
Originally Posted by dirkdiggler
I do really love the way the car looks, drives and sounds ......
Anyone else ever had the check engine light flash for a little while and then stay light solid??
Is it possible that the water logged failing Computer under the seat can cause the check engine light to flash.
There could be a myriad of reasons for the CEL. You can be certain you'll need to replace the computer (not impressive to your date when you pull out a hair dryer to start it). You could also have bad O2 sensors messing things up. Or it could be something else that will manifest itself after you've done these two replacements. The thing is, you can spend a pile of bucks chasing it.
You keep saying you love the way this box looks, drives and sounds. Other boxs will give you that same feeling without having that sucking sound of money flying out of your wallet.
Let me ask you - what are you able to afford? Is your budget only $4K so you think you can afford this box on a budget? Check out past posts about maintenance and you'll find wise owners of older boxs annually put $1500 into a maintenance fund. Spending your entire allotment for a problem child box is really going to send you upside down. If you can't afford a $9K box, you better wait or become friendly with a banker. If you think this $3K box is going to be cheap, you're in for a surprise. By the time you get done fixing everything, you'll have at least $7K invested. If you repair as you can afford it, you'll be driving this box in a couple of yrs but by then nice boxs will be worth $7K.
1989 928 S4 5 spd - black
