Old 07-03-2010, 12:42 PM   #2
JFP in PA
Originally Posted by blinkwatt
Thanks for the input fellas!
If there was an air bubble and I topped it off,the air bubble would still be in there unless I raised the bleeder valve correct? Or would it shoot itself out via the overflow hose?
Depends upon where the air is, the air pocket will remain unless the bleeder is opened or the system is put under vacuum (the prefered method). Sometimes you don't get it all out easily with the bleeder open, and you still have to pull vacuum..........
