Old 06-28-2010, 10:53 AM   #2
Dave S.
Dave S.'s Avatar
Thanks. I actually ran the windows all the way up and all the way down several times and they work fine, like I said, when you open the door, the window mechanism seems to drop, bu the glass only moves slightly down, and I can manually push the glass down another 1/4 inch or so by pushing down on the window. When you close the door, it goes all the way up.
It's a 2003 Boxster S with 20,000 miles on it. I was wondering if there is something that needs to be lubed or a part where the window connects to the mechanism that gets loose of worn ouy quickly. And I'm sure it doesn't help that my wife has a habit of closing the door by pushing on the window.
Dave S.
Originally Posted by pk2
You might do a search here. There is a trick that involves winding the windows all the way down (or up) and holding for 15 seconds. This resets your windows computer calibration. May or may not be your problem.
Regards, PK
Dave S.
2003 Boxster S
Dave S. is offline   Reply With Quote
