Old 06-21-2010, 11:46 AM   #17
Wret
That bearing set should work if the spacer ring is big enough. I actually have the same slide hammer. I tried it first and broke the adapter plate after about 30 or 40 good whacks. It is VERY cheaply made. The other type hub puller was my fall back and it worked like a charm.
I'll be taking the slide hammer back for a refund.
Wret is offline   Reply With Quote
