Also, wheel diameter is irrelevant when it comes to calculating offset. Initially, its the width of the wheel that is important. For example, to compare a wheel that is 17x9 +55 and one that is 19x10 +40 as it relates to where the wheel will sit in the fender well is based on the difference of width and offset. Essentially, the 19 inch wheel will result in 2 mm's more inner clearance than the 17, and the wheel will extend out toward the fender lip an additional 28 mm.
