Old 09-21-2009, 04:00 PM   #2
d18mike
This from the Dr. Color Chip Q&A section. I agree. I think you'll need to repaint.
Does it work well on all colors?
Chips on most car colors are dramatically reduced or eliminated. Light silver and gold metallic colors generally look much better after inital application, though sometimes are still more visible because the edge of the chip is slightly darker and will catch your eye if large enough. Sometimes with these colors and on larger chips, it's better to use the small-tipped brush and apply a small amount of paint and leave it as is.
One other point on light metallics: Some of our light metallics are made with domestically produced metallic flake, which is polished only on one side. When the paint is applied in a small blob, the flake will turn over and appear darker in color. This darker effect is apparent in the bottle and cap lid after shaking. Once smeared, the flake will re-align itself and appear bright again.
d18mike is offline   Reply With Quote
