Old 05-20-2009, 05:57 PM   #1
lostbrit
Dredd, the answer to your question is out there. Just keep your search simple, like "wind deflector."
Roll bars have holes that are predrilled on each of the hoops. You must pull off the padding to access them. The brackets are simply pop riveted to the roll bar hoops. The center bracket rivets to the center padding. Do a search on this forum for windstop and you should find a link to a site on renntech which gives you directions with photos from toolpants. Removing the rollbar pads is the most difficult part (you got to pull them off really hard). The remainder of the installation is simple.
lostbrit is offline   Reply With Quote
