Old 03-30-2009, 09:48 AM   #1
spine911
As mentioned previously double check the fuses, and relays..If not this could possibly be an internal speedometer problem, after you mentioned that all the needle markers (rpm, speed, temp, fuel) does not work, but all the other lights work..Also, id check the cluster connection- there are 2 main connectors for the cluster.
Goodluck.
spine911 is offline   Reply With Quote
