Originally Posted by vincesf
With some facelifts, it's best to leave the face alone, as the plastic surgeon, can botch it up. Some aspects look like an improvement, but I still don't like the rear drooping lights and the lower rear panels, which are now black so that you can spend an additional $1,000 to color match them or have them in aluminum look. The front middle intake looks a bit odd shaped (I like the Cayman's more), and the 2 front air intakes now have black louvers, which again will allow you to spend extra to have them color matched or painted grey to match the side air intakes. The headlights do distinguish it from the 911 a bit more, and look a bit more like the Carrera GT; however, IMO the rounder light are a better fit to the car's appearance. Interior ipod connection and new engines/transmission are big pluses. In short, if you already own one, it is not worth to trade up and perhaps it is better to wait a few more years for the all new Boxster. If you are in the market for one, perhaps wait until they work out the bugs or until a $5,000 power pack option is available to upgrade the Boxster S hp to be on par with the add'l 10 hp of the Cayman S.
If you go to the Porsche site and slog through the videos, there are lots of little tidbits. The base Box has body color radiator strakes. Only the S has them in black. The brakes on the base are the same as the S except for caliper color. The base uses the old engine block and internals but bored out to 2.9L. Only the S gets DFI. The 5 speed is dead in the base Box. It now comes standard with a 6 speed manual.
Amazingly enough the facelift was accomplished without changing a single body panel. Only the front and rear bumper caps had to be changed to accept the different shaped lights.
