Originally Posted by Kirk
Insite, what kind of settings are you using at the track?
tire pressures
sway bar settings
ride heights
shock stiffness
camber/toe
I'm trying to get my ride heights dialed in now. I think I was hitting my bump stops at my last autocross. I'd be curious to see how you've got your car setup for the track.
Kirk
tire pressures are 38 hot (or 38 cold at autox) front and rear. front gt3 sway is full soft. rear h&R sway is full soft on one side, full stiff on the other. shocks at the track were set at 31F, 30R. front camber is -1.5; rear is -2.0. front toe is zero and rear toe is VERY slight toe in. have to get back to you on the ride heights, but the rear is 1/2" higher than the front. it REALLY performs like this.
