Originally Posted by TimAustinW
So if you were going to replace your clutch and flywheel would it be a good rule of thumb to put in a new flywheel seal (RMS)? My Boxster is nearing 83K miles and I was told six months ago that I'd probably need to replace my clutch in six months. I've read here that lower mileage cars are more prone to RMS failure so will a new clutch, flywheel and new RMS open the possibility back up to RMS failure?
flywheel or no, replace the RMS everytime you have the tranny off. $20 insurance policy. if you haven't done it yet, replace the IMS bolts and rear case bolts with the microencapsulated versions.
BTW, there are some people who think that if you're lucky enough to have one that doesn't leak, don't replace it or you risk a leak with the new seal. this is garbage; the leaky cars leak because of out-of round issues on the case.
