randall -
don't just give them your car and say 'align it'. you have to give them the specs. they have neg camber on the front left and POSITIVE camber on the front right. this is in spec, but not technically correct. they should match (and i promise you your car is not the reason they don't).
in the rear, it looks like they could only get down to -1.9deg camber. what they should have done is match the other side to this setting, not simply leave it alone because the computer said it was okay.
your only real issue is the difference in caster between the front wheels. this is probably due to a bent strut and NOT to subframe damage. this problem will likely not exist when you install the ksports.
when you DO have the ksports installed along with your adjustable toe links, there will be NO excuse for not matching the left and right sides.
give them the alignment settings i posted earlier. tell them to hit them. if they can't, have them explain WHY and then tell them to at least match left and right to the same setting, even if it's not the ideal setting. all four corners on your car are so different that it must handle very badly. wait until you see how it feels when they're spot on.
