Old 06-07-2008, 08:50 AM   #1
musicboy
I did this
I had an S muffler modded this way. Living in a small city in Louisiana, none of the welding shops had the stainless steel tubing, so I did an internet search and bought the tubing and pre-bent angles (stainlees steel requires mandrel bending, which your shop may not be prepared to do) and then had a local shop do the welding and install. If I had to do it again, I would go with a larger diameter pipe - the 1" really is not loud at all. And no resonance. Do some searches on the various Boxster forums and you will find plenty of info and pictures.
musicboy is offline   Reply With Quote
