Old 04-28-2008, 10:09 AM   #1
kabel
I have. It is a lot of work, much more than I had anticipated.
If your on Renntech I sort-of took over another thread about a top, there are a couple pics there as well as some discussion of the process:
http://www.renntech.org/forums/index.php?showtopic=17836&st=20&p=94287&#entry94287
The material is not as clear as the original window material, but seems more supple and compliant. If you are not a hardcore DIYer and do not have someone to help you with the stitching I would recommend you find a shop willing to stitch in a new window with the canvas still on the frame. The entire convertible top (canvas & frame) is surprisingly easy to remove. Most shops want to remove the canvas from the frame, that is where it gets expensive.
Also see this thread where we touched on the subject:
Replacing plastic back window '01 Boxster's Top
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
