Old 03-18-2008, 05:03 PM   #1
renzop
You can often tell a bad wheel bearing with a forceful well placed shove. Kneel in front of the wheel. Place both hands on the wheel (at ten and two). Push in really hard. A bad wheel bearing will exhibit itself by a noticeable click-click. If that doesn't work, jack the car up so the wheel is off the ground and repeat your shove test.
Regards,
Alan
renzop is offline   Reply With Quote
