Old 03-10-2008, 09:09 PM   #23
pinzgo
Send a message via MSN to pinzgo
Intercooler. nos, methanol
PK,
I am counting DODOS (nights). I go down to FL to my condo at end of month for almost a month. Here we are going to have snow almost untill June !!!
I forgot to send you picture of fan already fixed inside trunk lid just under scoop. It is a powerfull 10 inches 1200 cfm. It will take air from outside, thru filtered scoop. Air will flow on intercooler and will evacuate by the two one way vents located on each rear side ot trunk. They look like shark Jaws. They have high capacity to evacuate and are weather tight. For intercoolers, I will put 4 CO2 foggers instead of aluminium tube. I will freeze them prior to spin the car by a push button located, as other systems switches, in ashtray. That's the messs you actually see on console picture. My only nightmare and probably you and your friends can help me. How to fix my Line Lock that permits to lock front wheels to heat rear tires. Brakes lines on porsche are not common like most of cars.
Enclose picture of fan
Good night boy
Jacques
pinzgo is offline   Reply With Quote
