Old 03-03-2008, 03:34 PM   #11
pinzgo
Send a message via MSN to pinzgo
Originally Posted by Kirk
Jacques, thanks for the updates and the photos!
So you got the universal radio DIN gauge pod from GLOWSHIFT? Is it this one?
http://www.glowshiftdirect.com/index.asp?PageAction=VIEWPROD&ProdID=253
What size gauges did you fit in there, 52 mm or did you have to go smaller? I REALLY like the fit in your car, it does look to be a perfect fit.
Kirk
Hi Kirk, It is the one. Direct fit with 52 mm. And there is a 12 v0lts unused plug in opening that allow you to plug them directly. For oil pressure one, there is a plug on left side of engine that let you fix the sensor.
take care
Jacques
pinzgo is offline   Reply With Quote
