Old 01-19-2008, 05:19 PM   #10
blue2000s
Porscheectomy
Originally Posted by Bob O
I have 7 mm front and 15 mm rear. I think they definitely improve the looks, and, according to a couple of knowledgeable folks, SHOULD improve things on the track. We'll see, since I'm going to a DE next Sat.
I have 17" wheels on my 01. How would adding these spacers increase any suspension stress over what increasing the wheel size to 18's and the tire size accordingly? Or what additional stress would simply increasing the width of the tire do???. I could put on 18's, which was an available size from the factory, and be at approximately the same relative position in the wheel well as putting on the spacers. I'm not convinced that any additional stress results over what the factory has allowed for in the design.
Now if we're talking about 50 MM spacers.. that's another matter! but the 7 and 15's are actually pretty small.
Just my .02
Bob
When you look at the stress on the wheel bearings, you typically want the tire to overhang the bearings by an equal amount on both sides. This minimizes the moment in the axial direction of the axle. It basically reduces the force that wants to twist the bearing out of the race.
Assuming the tire is centered on the bearings stock, when you add a spacer, you add to this load. It will slowly wear more on the wheel bearings. The larger the spacer, the larger this load.
Is it significant? Probably not, but it is real.
