Old 11-29-2007, 03:14 PM   #4
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by insite
why change the flywheel? curious.
You can pay to replace it then or down the line. If you wait to replace it down the line it will only cost you $500+ to take everything apart again.
At 52k my original flywheel had a blue burn marks on it,about a 1/2" wide. Plus every shop that I called for a clutch job advised me to just change out the flywheel as well. A mechanic told me that when the clutch disc is worn that's when the flywheel gets damaged,as to what happens when the clutch is worn I'm not sure.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
