Old 11-11-2007, 10:17 AM   #4
2000SoCalBoxsterS
Thank you all
Thank you all for replying. I bot some cleaner and I will see if that works. I have heard that a new MAF costs about $400.
BTW, I also found that another cause of MAF malfunction and damage is from the oil separator bellows hose. Apparently this rubber hose will deteriorate from heat and oil and allow air to enter the intake system. It is a flexible hose that connects the separator to the engine and is located below the oil separator. It is most easily viewed and replaced from below when the car is on a lift. I'm going to check the integrity of this rubber hose too. Probably a good idea to inspected this hose at each oil change to head-off and potential actual MAF damage.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
