Old 08-01-2007, 09:13 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by djomlas
i was trying to remove my spoiler few days ago, and no luck. i cant seem to get those little black tabs out, any pointers man?
They are simply plastic rivets. Use a hole punch or pin to push the middle pin through. The pin will simply fall into the bottom of the spoiler. You can remove and reuse them when you reinstall the spoiler or buy new ones (they're cheap at the dealer). After pushing the pin thru, the rivet will be easy to pull out. Then, just pry off the top painted cover of the spoiler. Look down, and you will see 2 allen head bolts. Undo them, and the spoiler frame will pull out completely.
