Thread: cdr220 pos
Old 06-14-2007, 05:50 PM   #1
yellowboxster01
Originally Posted by MNBoxster
Hi,
You need to pull the Faceplate and clean the Brass contacts on both the Faceplate and Head Unit with a Q-tip and some Rubbing Alcohol. Then, carefully reattach it so as to be sure that all the contacts line up. This should solve your problem.
The Faceplate actually contains microprocessor circuitry which controls the HU. If the contacts get dirty, or misaligned, it don't work. Hope this helps...
Happy Motoring!... Jim'99
well, thank you very much. cleaned the contacts and voila it works. thanks again Jim!
yellowboxster01 is offline   Reply With Quote
